Migrate windchillDS to OpenDJ
RP_10484037
7-Bedrock
Version: Windchill 13.0
Use Case: Migrate windchillDS to OpenD
Description:
I have recently migerated WindchillDS to OpenDJ. However I am getting below error in MS logs while starting windchill service
2024-06-07 11:01:39,006 FATAL [main] wt.method.server - MethodServerMain abort wt.services.ManagerException: Unable to start all managers.
Nested exception is: (wt.services.servicesResource/21) wt.services.ManagerException: Unable to start manager: "wt.audit.AuditService" with implementation class: "wt.audit.StandardAuditService"
Nested exception is: wt.services.ManagerException: Could not initialize Auditing service.
Nested exception is: wt.org.OrganizationServicesIEException: javax.naming.CommunicationException: slwebn0019.corp.mattel.com:1389
at wt.org.LdapServices.queryPrincipalsFromLdap(LdapServices.java:1181)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:566)
at wt.services.ServiceFactory$ServerInvocationHandler.invoke(ServiceFactory.java:399)
at com.sun.proxy.$Proxy67.queryPrincipalsFromLdap(Unknown Source)
at wt.org.StandardOrganizationServicesManager._queryPrincipals(StandardOrganizationServicesManager.java:12292)
at wt.org.StandardOrganizationServicesManager._queryPrincipals(StandardOrganizationServicesManager.java:11556)
at wt.org.StandardOrganizationServicesManager._queryPrincipals(StandardOrganizationServicesManager.java:11513)
at wt.org.StandardOrganizationServicesManager._queryPrincipals(StandardOrganizationServicesManager.java:11498)
at wt.org.StandardOrganizationServicesManager._queryPrincipal(StandardOrganizationServicesManager.java:11405)
at wt.org.StandardOrganizationServicesManager.getAuthenticatedUser(StandardOrganizationServicesManager.java:3128)
at wt.org.StandardOrganizationServicesManager.getUser(StandardOrganizationServicesManager.java:3265)
at com.sun.proxy.$Proxy66.getUser(Unknown Source)
at wt.session.StandardSessionManager.getUser(StandardSessionManager.java:454)
at wt.session.StandardSessionManager.getAdministrator(StandardSessionManager.java:326)
at wt.session.StandardSessionManager.setAdministrator(StandardSessionManager.java:289)
at com.sun.proxy.$Proxy56.setAdministrator(Unknown Source)
at wt.audit.StandardAuditService.performStartupProcess(StandardAuditService.java:294)
at wt.services.StandardManager.startup(StandardManager.java:459)
at wt.services.ManagerImplementation.startup(ManagerImplementation.java:363)
at wt.services.DefaultStartupHandler.startup(DefaultStartupHandler.java:112)
at wt.services.StandardManagerService.performStartupProcess(StandardManagerService.java:167)
at wt.services.StandardServicesHandler.start(StandardServicesHandler.java:44)
at wt.method.MethodServerMain.run(MethodServerMain.java:584)
at wt.method.MethodServerMain.main(MethodServerMain.java:353)
2024-06-07 11:01:39,007 FATAL [main] wt.method.server.shutdown - Stopping services...
2024-06-07 11:01:39,008 INFO [main] wt.method.server.shutdown.services - All managers shut down.
2024-06-07 11:01:39,008 FATAL [main] wt.method.server.shutdown - MethodServer stopped
It seems Windchill is unable to communicate with the changed LDAP. Check this article. There is also a tech support video on the migration.
regards
~Syed
olivierlp
Community Manager
(To:RP_10484037)
Hi @RP_10484037 ,
I wanted to see if you got the help you needed from @shussaini.
If so, please mark his reply as the Accepted Solution. It will help other members who may have the same question.
Olivier
Just a comment.
These messages indicate that a connection cannot be made. Too bad it doesn't say exactly that:
- Unable to start all managers
- Could not initialize Auditing Service
There is nothing specific about the Auditing Service - it just happens to be the first one.
