Assuming need to migrate from Intralink to PDMLink. In intralink : current rev scheme 1.1 1.2 1.3 ... 1.99 2.1 2.2 2.3 ... 2.99 etc What will be revs scheme in PDMLink for EPMdocuments in order to bring them from Intralink with the same revs scheme? appriciate any advices.
Dmitry, you can define the same sequence in PDMLink. The mapping is defined by sequence (first to first, second to second ..), so if the sequence is the same the result after the migration will be the same.
