Version: Windchill 13.0
Use Case: Data migration between different Windchill versions
Description:
Here is the main hub for all things import/export: https://www.ptc.com/en/support/article/CS175236?source=Bloop
Sounds like packages might be what you want for the test data. This shows compatibility between versions: https://www.ptc.com/en/support/article/CS323534?source=search
I think the 11.2 version might be your problem but that version is unsupported currently. If you are developing custom solutions that you want to have work in 11.2, I would consider just upgrading them to eliminate that version from consideration.
I do not think exporting a workspace is possible. I have never heard of that being done. I think you would be better suited recreating that to a specification for testing in each system. Workspaces are temporary things which just contain specific iterations of objects. They can be created and recreated easily enough.
Hello @Pratik_More,
You have a response from our community champion. If it helped to answer your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
