Missing leader lines on annotations in Creo View
Mark_Stahlkopf
Trying to show model annotations (note with leader lines) in Creo View. I can see the text but, the leader line is missing. How do I get everything to show?
So, just to close this out. The answer for this is to have both Positioning Assembly &  Extended Positioning Assembly set to YES.
9 REPLIES 9
Version of Creo View? Version of Creo View Adapters? Version of Creo?
Creo 8.0.4.0
Creo View MCAD 8.0.0.0 build 27
Are you generating the PVZ directly from Creo, or through a Windchill CAD Worker
PVZ's are generated by the CAD Worker.
Send a screen shot of rcp file or listed of text file. Also, have you turned on all filters?
Also found this SPR:
https://www.ptc.com/en/support/article/CS364811?source=search
All Filters are on. I will check the RCP file.
I would follow up with Tech Support as I think that reported SPR I noted is likely the cause.
I'm having the same issue, but I can't find where to change the options you mention here. Are these positioning options that need to change located in Creo View or in the configuration editor within Creo? I haven't been able to locate them in either place.
For reference, I'm running Creo 10.0.2.0 and Creo View 9.1.
