Trying to show model annotations (note with leader lines) in Creo View. I can see the text but, the leader line is missing. How do I get everything to show?
So, just to close this out. The answer for this is to have both Positioning Assembly & Extended Positioning Assembly set to YES.
Version of Creo View? Version of Creo View Adapters? Version of Creo?
Creo 8.0.4.0
Creo View MCAD 8.0.0.0 build 27
Are you generating the PVZ directly from Creo, or through a Windchill CAD Worker
PVZ's are generated by the CAD Worker.
Send a screen shot of rcp file or listed of text file. Also, have you turned on all filters?
Also found this SPR:
https://www.ptc.com/en/support/article/CS364811?source=search
All Filters are on. I will check the RCP file.
I would follow up with Tech Support as I think that reported SPR I noted is likely the cause.
I'm having the same issue, but I can't find where to change the options you mention here. Are these positioning options that need to change located in Creo View or in the configuration editor within Creo? I haven't been able to locate them in either place.
For reference, I'm running Creo 10.0.2.0 and Creo View 9.1.
