Modelcheck
Amirtharaj_K
Modelcheck
Hi Everyone,
I am working with model-check to add the new parameters, but I can't able to add a run-by model check. I tested in Creo parametric to run the interactive model check there I got parameters.
Thanks in Advance,
Amir
Thank you for your question.
I encourage you to bring more details and context to your initial inquiry. This will make it easier for you to receive meaningful help from other Community members.
Andra
Thanks for the reply and suggestion.
I am looking for an automatic geometry check - reference, missing components, add & rename parameters, parameter value get from Excel, and upload/add-in model kind of way I looked. I found that Modelcheck can do that. I want to know how to do that.
I tested in Creo Parametric few things worked for example adding new parameters, but we can do it manually. One more way I found we can use the modelcheck.bat file to upload the new parameter into the CAD model from the .txt file.
Amir
