This symbol, seen in your workspace columns, means that changes to a file have been uploaded to the server. How do you reverse this besides removing the modified items from the workspace?
Removing and re-adding those items is the only option I know. You may create a brand new workspace discarding these changes.
Ajit
If you want to keep them then you need to also check them in.
If you don't want to keep the changes the you can use the Update button.
Uploading doesn't mean they were checked in.
Use the green plus button to replace them with the original downloaded from commonspace
I didn't wanted to muddy the waters by stating what I have tried or what I know will work, which is a method I don't like. I've received three answer up til now and will respond to each:
Are there more ideas? Thanks.
Due to workspace background operations, you may need to manually refresh the workspace shortly after performing an update...
From Tom's link, this is the set of instructions that did it!
Object is not checked out, modified, and uploaded
