More -Revise & checkout only exists in a Pro/e session & no dependents collected
kjohns101
This should be allowed in workspace or commonspace but really belongs in search results.
Why do we have to start a pro/e session to accomplish this task.It also should collect all
dependents with the option to check out & revise
jellis
(To:kjohns101)
In Reply to kevin johnson:
A New Revision is allowed/permitted from a stand alone browser connection to PDMLink. You do not have to have a ProE session running to create New Revision. As well, from a Search results list you can select the object and then select the Actions menu and then New Revision to revise the object and its dependant/associated objects.
Regards, Jim
<this should=" be=" allowed=" in=" workspace=" or=" commonspace=" but=" really=" belongs=" in=" search=" results.<=" p=">
dependents with the option to check out & revise>
