Most commonly used components
Highlighted
Aquamarine
This query can be used to find the components that are most commonly
called out on BOMS (Product Structures).
SELECT COMPONENT, COUNT(*)
FROM
(SELECT DISTINCT M1.WTPARTNUMBER COMPONENT, M2.WTPARTNUMBER ASM
FROM WTPARTMASTER M1, WTPARTMASTER M2, WTPARTUSAGELINK, WTPART
WHERE
M1.IDA2A2 = WTPARTUSAGELINK.IDA3B5 AND
WTPART.IDA3MASTERREFERENCE = M2.IDA2A2 AND
WTPART.IDA2A2 = WTPARTUSAGELINK.IDA3A5 AND
WTPART.IDA3VIEW = 1447) MYTABLE
GROUP BY COMPONENT
HAVING COUNT(*) >10
ORDER BY COUNT(*) DESC
The query discounts effects of iterations so the count is not skewed by
one BOM having numerous iterations.
The HAVING and ORDER BY clauses are optional. I could care less if a
component was used only once since I was looking for the most frequent.
The where clause for views, WTPART.IDAVIEW, is also optional. I was
filtering on a secondary view version.
My goal was to determine the most commonly used components and make a
helper BOM. My users can call this BOM up in a secondary PSE window and
copy/paste from it to their assembly.
