Mouse-Problems with 1920x1200 resolution (?)
Guest
Pro/Gurus,
my problem is a jiggle by picking entities in 3D, sketcher and drawing.
Moving the pointer over the entity and click ProE is not that sure with
selecting like in 1280x1024 resolution.
I thought, that it is caused from Logitech SetPoint 3.1.116 - 64bit driver
(elder versions too). In another forum somebody mentioned, that it is caused
from resolution. I can only confirm, that it started with new OS (XP64bit
SP1) and monitor (HPLP2465 24" 1920x1200). The same Logitech SetPoint-driver
with XPPro 32bit and 1280x1024 resolution had not had this issue.
Can anyone out there confirm this problem, is this caused from the mouse
(Logitech???) or from the resolution?
I'm on WF2 M220, is there hope to get rid the "Parkinson" with M230 or M240?
Are there any issues?
TIA Uwe
Engineering Office Uwe Driehaus
Im Brachfeld 6
D-53819 Neunkirchen-Seelscheid
fon : +49 / 2247 / 74 55 90
fax : +49 / 2247 / 74 55 91
www.driehaus.de <http: www.driehaus.de="/>
mailto:uwe.driehaus@driehaus.de
