Move the username
Tanzanite
Move the username
Is there any way to move the location of where the username displays in the banner?  We recently upgraded from 10.1 to 11.0.  The company logo I use is too wide in the new version.
Re: Move the username
Hi @STEVEG,
To do this follow below steps:
  • modify "C:\ptc\Windchill_11.0\Windchill\codebase\netmarkets\javascript\util\jsfrags\navigation\navigation.jsfrag" file and locate below line:
<table><tr><td><div id="logoNav" class="' + PTC.navigation.HEADER_CLASS + '"></div></td><td><span id="globalUser"></span></td></tr></table>
  • Add couple of &nbsp (HTML spaces) before globalUser element as shown below.
<table><tr><td><div id="logoNav" class="' + PTC.navigation.HEADER_CLASS + '"></div></td><td>&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp&nbsp<span id="globalUser"></span></td></tr></table>
  • Save these changes
  • Run below command from Windchill Shell:
ant -f bin\jsfrag_combine.xml
  • Make sure command run successfully
  • Stop Windchill Method Server
  • Clear Tomcat & Info*Engine cache
  • Restart Windchill Method Server
It will looks like below:
Note:
  • If need be, you may also have to clear browser cache too.
  • These are the instructions for your reference purpose only. Make sure you follow Customization best practices to avoid any maintenance/update/patch installation override.
I hope this will help you.
Best Regards,
Shirish
Thank you for that.  I have been so incredible busy since our upgrade because of problems with it, or end or year tasks that I haven't been able visit this community.  Things are starting so slow down now.  I didn't want to mark this as accepted yet until we can try it to verify it works.
