Moving a file vault when the fileserver is no longer available
Highlighted
Aquamarine
Folks,
I need to move a file vault from a fileserver that is no longer available. The DMSU requires a password for the old fileserver, so I cannot use that interface. I have already moved the physical files (from backup) to a new fileserver.
I want to use the sql commands:
update pdm.pdm_fileserver set FSVHOST='new_server',FSVPORT='7777' where FSVID=359;
update pdm.pdm_pool set POOLHOST='new_server',POOLPATH='new_location' where POOLID=425;
Do I need to stop and restart the dataserver for these changes to take affect??
Daniel Nordin
BAE Systems
Electronics & Integrated Solutions
ET&S MCAE Support Group
Nashua, NH 03061
Highlighted
Summary: Moving a file vault when the fileserver is no longer available
Folks,
Two replies said that I did NOT need to restart the dataserver. One reply said YES I do. I moved the vaults over to an existing fileserver so I only needed the to use the
command. I did not need to restart the server. I can access the files without issue. Thanks to those that responded.
Daniel Nordin
BAE Systems
Electronics, Intelligence & Support
Nashua, NH 03061
