We are using 10.1M040 which officially supports IE8 and IE9. We found later versions not to work correctly with WGM.
Within the business we have other tools which require higher versions of IE in order to function correctly. We thought a work around for this would be to use the embedded browser in Creo and WGM. We tested this OK on a few machines and rolled out this change recently to every client. We had immediate corporate meltdown with many CAD users experiencing serious problems, and were forced to hastely reverse this change.
I was planning to ask if anybody else had experienced issues with embedded browser.
Has anyone found a solution to this? We are evaluating Firefox since all the IE security issues is forcing us to go to IE 11 (does not work with Windchill 10.1). We are getting the hangs on collecting related data.
David R. Martin II
Senior CAD Application Specialist
Amazon
I confirme With Chrome beta 36 and Chrome Canary (Dev 37) the tab problem in Windchill10.X is solved. There is a case open on PTC support :https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS172436&posno=3&q=chrome&nav=&source=Search.
I hope the official chrome version 36 will be deployed as soon as possible. Our users back to IE but with the navigation speed between us is huge.
Couple of things,
I recommend don't going to java 1.7. Stay with Java 1.6.0_45 or higher. Second, what version of IE are you on. Google Chrome plug-in may help. Just make sure in your IE options, your active X is all enabled and your java securities are at the lowest. Also, IE options, general, settings, check for new version, is set to every time I visit the web page.
I had many of discussions with PTC technical support with calls, and all of them told me to stay away from Java 1.7.0. until 10.2. It is just too many issues to deal with. After you have installed Java JRE 1.6.0_45 on all the clients, you have to change the clients registries so that Java JRE doesn't auto update on the clients.
Good luck,
Patrick
In Reply to Ian Bagnald:
We've recently been using the embedded mozilla browser due to what seems like constant ie/windchill annoyances. One of my users sent me this, does anyone have any advice?
> The Mozilla Browser is not working to “Collect Related Data”. For example, if I select a generic model for checkout I should be able to collect all the related instances of that model, but when I try the interface just sits there spinning . . . . . . other users have experienced the same thing.
Ian Bagnald, CISSP
Sr System Support Analyst
If some of your clients are still using Windows XP, IE 8 is the highest. And yes, some clients stil use XP even though Windows has stopped placing patches on the OS since last April.
Good Luck,
Patrick
Ian Bagnald, CISSP
