NX Integration
BL_9537051
NX Integration
I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS22
NX integration configuration
1. How to distinguish between models and engineering drawings
2. How to distinguish between parts and components
3. How to distinguish the specified type when checking in a model
Translated by the moderation using Google Translate
NX集成配置
1.模型跟工程图如何区分
2.与部件关系怎么区分
3.模型检入怎么区分指定的类型
I would start here if you have not already done so: https://www.ptc.com/en/support/article/CS374713?source=search
If there are settings that control this, it would be the site - preferences or the WGM ini file.
Hi @BL_9537051 ,
If so, please mark the appropriate reply as the Accepted Solution or please feel free to detail in a reply what has helped you and mark it as the Accepted Solution. It will help other members who may have the same question.
Catalina
PTC Community Moderator
PTC
