Version: Windchill 13.0
Use Case: I need to hide the CAD Document attribute SAP_MATNO dynamically based on context in the windchill UI
Description:
Windchill Version: 13.0
Object Type: CAD Document
Internal Name: com.trw.ssc.DefaultEPMDocument
Attribute: SAP_MATNO (IBA)
When the CAD Document is created/edited/viewed inside the container named “Training”, the attribute SAP_MATNO should be visible in windchill ui.
In all other containers, the attribute must be hidden in windchill ui
The logic must work consistently across:
View information page
I implemented an AttributeDataUtility class to check:
The attribute name
The CAD Document type (com.trw.ssc.DefaultEPMDocument)
The current container (resolved via NmCommandBean + TeamCCHelper)
Then the utility sets:
attrState.setVisible(false)
attrState.setReadOnly(true)
attrState.setValue(null)
However, I want to confirm:
Whether this is the correct approach in Windchill 13.0, or
Should I instead use UI Validation – Pre-Validation (Validator + service.properties.xconf mapping)?
Find the best supported method in Windchill 13.0 to hide a specific attribute for a specific CAD Document subtype based on current container name.
Confirmation of the correct mechanism (DataUtility vs UI Validator) coding would be helpful
Example of a recommended implementation
Required XCONF registration steps
Just to confirm, your data utility method, do you have this working? Strange requirement. What the purpose of having this attribute only for Training context?
