Need help with PTC_ORGANIZATION_ID
SA_12455883
7-Bedrock
I am using Windchill PDMLink Release 12.1 and Datecode with CPS 12.1.2.16
Is it Possible to change PTC_ORGANIZATION_ID (edit the attribute and change the organization value) for already checked in parts? found article but not able to add the attribute in table view for manual edit
https://www.ptc.com/en/support/article/CS432157
Article https://www.ptc.com/en/support/article/CS388883 needs the update with below note as its hidden by preference which is not mentioned in article
  • Note:The Set Org ID action only display when the preference Site>Utilities>Preference Management>DisplayExpose Organization = Yes
ref article:https://www.ptc.com/en/support/article/CS153744
