Version: Windchill 13.0
Use Case: old iteration sub-assembly having the same latest revision of components as in the latest subassembly. * the components in the subassembly not released for very long time
Description:
Old iteration sub-assembly having the same latest revision of components as in the latest subassembly.
* the components in the subassembly not been released for a very long time
why I am seeing the latest components' iteration in the old sub assembly?
Its based on the default configuration specification which is latest. You can bring down a specific iteration of an assembly with latest of the components. If you want to see it like it was, you need to choose "as-stored" when you download it.
Hi @MS_10437608,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to help you.
Anurag
