Version: Windchill 13.0
Use Case: I'm fairly new to this PTC suite, and I'm trying to link Creo, to this. The main use is to manually add WT Parts as well, but I'm unable to.
Description:
Everywhere I look online, I'm seeing a grey gear icon that has "create new part" in a product folder. However, I'm not seeing that:
Note, that the Creo Models folder was manually added. Additionally, I've tried creating a new product with a different template and tried that, and it didn't work.
Any tips in general would be greatly appreciated!
Usually the described problem occurs when you do not have the license that allows the creation of the WTPart.
Matrix License Profile/Windchill PLM (UI Actions and Functionalities) in Windchill PDMLink
If, in other products you are able to see the icon "Create New Part" and its missing only in this product, then its clearly an Access Control Issue (ACL).
You need to speak to your windchill admin.
If you have access to the "Team" node of the product, you can compare your ROLE in this product and the others.(for your understanding).
Let us know,
Cheers
Hari
