I am using Windchill PDMLink Release 11.0 and Datecode with CPS M030-CPS17
After the component is changed, it is version F, which is accurate, but the drawing is still version E. The F.7 version of the drawing does not seem to be associated. The automatic check-in at that time was also successful. What is going on?
Translated text from Simplified chinese to English using google translate: -
Title :- 新图纸检入没有关联最新部件
Body :- 部件变更后是F版本,已生准,但图纸还是E版本,图纸F.7版本好像没有关联上,当时自动检入的,也检入成功了,这个怎么回事呢
The default I believe is as-stored. If the other version of the component is in the workspace, the drawing will use that as its configuration. Make sure the workspace has no out of data components when it is checked in. Also did you revise the drawing when you revised the component?
They are separate objects.
Hi @宋畅_10666569
Check if the drawing has been updated regenerated after the model had been modified.
If the drawing is not updated/regenerated, it still shows the as stored state
PS: yes @avillanueva is right. if the drawing is opened from a workspace to creo, it depends what version of objects are loaded in the creo session memory.
PetrH
Hello @宋畅_10666569,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Community Moderation Team.
