I was asked to provide a report of the latest version of all drawings at either Released or Prototype Released.
Search allows you to do this because the logic applied is:
- (Filter out anything by state / context that you don't have READ access to)
- Filter out non-latest iteration each Revision (hard-coded in search)
- Use any State criteria; filter out any not any those state(s)
- Depending on preference, return latest of what remains or all (default - latest)
For this data you get B.2 Released as required - essentially search allows you to apply a config spec including state to CAD Doc's (or other)
A.1 In Work
A.2 Prototype Released
B.1 In Work
B.2 Released
C.1 In Work
But, Creating a query builder report to apply the logic in this same sequence turned out to be tricky. By default the qml logic is:
- Filter out non-latest iteration each Revision (direct criteria)
- Find latest using standard sub select on branch id
- Then, apply any State criteria
If you filter out for example In Work, it returns nothing for the data above.
Kudos to tech support engr Jaysel Meledath at PTC who kept with this and figured it out using the appropriate sub select. Seems like it might be helpful to others - leaving it to PTC to make available.
Got it working by adding an extra criteria for State = RELEASED in the sub-select for the maximum Version Sort id
Can you share the QML of this report? Or screen shots?
You can find lots of report ready to use in this document https://community.ptc.com/t5/Windchill-Questions/Resource-for-reporting/td-p/448738
Except I'm still not finding what I'm looking for. I need to report that Latest Released Revision of a WTPart. There may be multiple Revisions of this part that are Released and the Latest Revision, regardless of State, may be In Work. For example:
PART12345 Rev. A.1 Released
PART12345 Rev. B.1 Released
PART12345 Rev. C.1 In Work
I want the report to send back the Latest Released Revision, which in this case is Only PART12345 Rev. B.1
The QML examples I tested came back with Blank results because the Latest, PART12345 Rev. C.1, is NOT Released.
In my document there's a link to this TS article.
https://www.ptc.com/it/support/article?n=CS142076
Doesn't meet your requirements?
Nope. These are the reports tested. If I want Latest Released, but the latest Rev is In Work, the report is blank, even if the previous Rev is Released.
These QMLs are filtering on the Maximum Branch ID, then filtering on the State, What I need is the opposite. I've tried adding a Sub-Select to the Sub-Select, but that doesn't seem to be supported functionality.
You cannot use query builder to do recursive query.
Have you already tried to add a criteria for the state in your sub-select?
If affirmative, I suggest you to open a case with TS and ask what they would do in this particular case.
Hi Mike,
I am running into this same issue.
Reading the final lines it looks like Tech Support (Jaysel Meledath) supplied you with the correct sub-select to get this done.
Can you share it here as well?
Hello ,
I applied the same query , i get result as expected.
but..
for few data the result is not expected its giving me the WIP data as the latest one , it should give previous released data.
any help on this issue will be appreciated.
Nimish
You can't add a comment to a discussion that has an accepted solution already for two and a half years.
You'd better open another discussion, referencing this one to say it's not enough, if you want someone to be able to help you.
