After what appeared to be a successful rehost (primarily using the rehost guide), I get the following message in my browser: "Windchill Error: No EnumeratedType exists with "WIP" as its internal value."
WIP is a Lifecycle State that we defined during our 3.4 to 9.1 migration last summer. It's part of the ILNK Life Cycle which all our stored objects are controlled by.
I'm a bit mystified as to what's causing this: aren't lifecycles stored in Oracle? I can see contexts, teams, users, groups,promotion requests and folders, but not files. I'm wondering ifthere is a step or twothat I might have missed...
I did the following steps:
We have a simple setup: no adapters to other systems. Basically a simple 3.4 system re-implemented in 9.1. We made some changes to a couple of OIRs (e.g. to disable auto-numbering..) but nothing drastic. I was under the impression that most of the changes are stored in the system itself, like in 3.4.. Am I missing something?
The only glitch I suffered was that I screwed up Aphelion (didn't shut it down when importing the root.ldif from the production system) and had to uninstall/re-install it. Otherwise everything worked the way I expected it to.
I'll try re-importing the dump file again tomorrow to see if that does anything.. If I get the same error, I'm not sure what I should do.. Perhaps if I mirrored the \Windchill_9.1\Windchill folder over to the test system?
If anyone sees something wrong with this, please let me know. (don't waste too much time on it)..
Andrew Mansfield
KI, Green Bay, WI
