Node-Locked & Floating License
Ahmed_Afeen
2-Explorer
Hi All!
I would like to ask, what is the difference between "Node-Locked" of Heavy & Light License and "Floating" of Heavy & Light License?
Kindly reply as soon as possible.
Thank you once again!
Ahmed Afeen, Design Engineer
Here it is:
1. What is a node-locked license?
  • A node-locked or simply fixed license is a FlexNet license file configured to hostID of a specific machine.
  • Does not require the machine to connect to a FLEXnet server.
  • Only allow the PTC applications to run on that specific machine.
2. What is a floating license?
  • A floating license refers to a licensing scheme where the permission to execute the PTC product is controlled by the FlexNet server (the PTC license server).
  • In the FlexNet server environment any machine configured as a client will be allowed to use floating licenses until the number of licenses purchased has been exhausted.
  • The installation of a floating license(s) requires an authorization string, which is specific to the number of licenses (seats) purchased, the expiration date and the PTC_HOSTID for the machine to run the FLEXnet server program.
