Version: Windchill 12.1
Use Case: I want to create custom revision to revision link to describe the relationship between two soft types.
Description:
I am getting below error when im clicking on 'Relationship Constraints' tab in Configurable Revision Link -
Stacktrace -
2024-08-23 16:27:17,072 ERROR [ajp-nio-127.0.0.1-8010-exec-2] com.ptc.mvc.controllers.ExceptionController wcadmin - message : tmClientLaunchContainerRef can not be null while invoking RelationshipConstraintsTreeHandler.
error:-------------java.lang.IllegalArgumentException: tmClientLaunchContainerRef can not be null while invoking RelationshipConstraintsTreeHandler. java.lang.IllegalArgumentException: tmClientLaunchContainerRef can not be null while invoking RelationshipConstraintsTreeHandler.
at com.ptc.core.lwc.client.treeHandler.RelationshipConstraintsTreeHandler.<init>(RelationshipConstraintsTreeHandler.java:117)
at com.ptc.core.lwc.client.mvc.builders.RelationshipConstraintsLeftPaneBuilder.buildComponentData(RelationshipConstraintsLeftPaneBuilder.java:164)
at com.ptc.jca.mvc.components.DefaultJcaComponentDataBuilder.buildRawData(DefaultJcaComponentDataBuilder.java:71)
at com.ptc.mvc.components.ds.AbstractDataSourceComponentDataBuilder.buildComponentData(AbstractDataSourceComponentDataBuilder.java:266)
at com.ptc.mvc.components.ds.AbstractDataSourceComponentDataBuilder.buildComponentData(AbstractDataSourceComponentDataBuilder.java:80)
at com.ptc.mvc.components.ComponentController.getComponentDefinition(ComponentController.java:261)
at com.ptc.mvc.components.ComponentController.handleRequest(ComponentController.java:102)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:51)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:1071)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:964)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:1006)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:909)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:696)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:883)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:779)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:227)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:162)
at com.ptc.core.ui.validation.URLValidationFilter.doFilter(URLValidationFilter.java:86)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:189)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:711)
at org.apache.catalina.core.ApplicationDispatcher.doInclude(ApplicationDispatcher.java:578)
at org.apache.catalina.core.ApplicationDispatcher.include(ApplicationDispatcher.java:517)
at org.apache.jasper.runtime.JspRuntimeLibrary.include(JspRuntimeLibrary.java:994)
at org.apache.jsp.netmarkets.jsp.lwcType.newRelationshipConstraintLeftPane_jsp._jspService(newRelationshipConstraintLeftPane_jsp.java:372)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:70)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:466)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:379)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:327)
at wt.licenseusage.licensing.LicenseFilter.doFilter(LicenseFilter.java:47)
at com.ptc.core.components.filter.JCAFilter.doFilter(JCAFilter.java:97)
at wt.httpgw.filter.WTContextBeanFilter.doWithWtContextBeanHandler(WTContextBeanFilter.java:104)
at wt.httpgw.filter.WTContextBeanFilter.doFilter(WTContextBeanFilter.java:58)
at wt.servlet.CompressionFilter.doFilter(CompressionFilter.java:301)
at wt.servlet.RequestInterrupter.doFilter(RequestInterrupter.java:335)
at wt.servlet.ServletRequestMonitor.doFilter(ServletRequestMonitor.java:1677)
at wt.servlet.ServletRequestMonitorFilter.doFilter(ServletRequestMonitorFilter.java:57)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:197)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:97)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:541)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:135)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:92)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:78)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:360)
at org.apache.coyote.ajp.AjpProcessor.service(AjpProcessor.java:433)
at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:65)
at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:893)
at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1799)
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
at org.apache.tomcat.util.threads.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1191)
at org.apache.tomcat.util.threads.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:659)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.base/java.lang.Thread.run(Thread.java:834)
Screen shot -
Please help.
Can you describe or show your configuration of this link with setup UI? I assume tmClientLaunchContainerRef is your name for this link?
I am getting this as error when wizard opens for creation any custom relationship constraints.- com.ptc.mvc.controllers.ExceptionController wcadmin - message : tmClientLaunchContainerRef can not be null while invoking RelationshipConstraintsTreeHandler.
Hi @avillanueva tmClientLaunchContainerRef is the error that i m getting when clicking on relationship constraints. I want to create a relationship between two wtpart soft types but im able to do so in Type and Attribute Manager due to the error attached in screen shot above. Please help if anyone has faced such issue before.
Hi @PK_9881178,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
