Number of places for reporting
SOLVED
Re: Number of places for reporting
OK.  Thank you for your help.
I figured out how to set it to show the actual values.
On the Select tab add the function "To Number".
Select somewhere else on the tree to get it to display correctly.
Then select the To Number and then Add button again.  It will give a sub-entry:
This now shows whatever the value in the attribute actually is.
It is something convoluted in the same way to get the very latest revision.
Marco
But it is much easier.
I don't think I would have found it without your suggestion of the DATEDIFF function.  I started thinking there has to be some other function that does this so I tested several others and came across the To Number.
So thank you Marco!
So now that we migrated to version 11.0 M030 the "To Number" is not longer needed.  I originally needed it in 10.1 to make it show as a real number.  I have removed that.
WOW!
We have just moved to 11.1 earlier this year and I was looking to use the DATEDIFF function just today, but found that is is not present.  It does still show up in the WC Help for 11.1 though.  Does anyone know if this has been deprecated?  Subtract might work... but not the same as DATEDIFF where you can specify the time component which to compare (e.g. days, hours, weeks, etc).  That is a handy function.
