OIR Location
RonHarkins
7-Bedrock
OIR Location
Hi all,
Our business has a need to assign folder location via an OIR with a unique need: assign the location "incrementally" from the location where the create new object action was started. If the user has navigated to /Default/Project A and a subfolder in Project A is called Documents, then what are the OIR statemenr required to set the location in the OIR incrementally, i.e.
folder.id = <current location of action start>/Document
The intent is to use the OIR to support multiple subfolders locations based on where the create action was triggered:.
Default
    Project A
        Documents
    Project B
        Documents
    Project C
        Documents
TIA
0 REPLIES 0
