OIR - prefixing an OData Number generator in specifiedItem rule
TJ_10505309
6-Contributor
Version: Windchill 12.0
Use Case: I need to prefix the output of the algorithm="ext.xxxx.xxxx.external.xxxx.impl.ODataNumberAlgorithm To be prefixed by "C", if _rootNumber id "7000000", what syntax do I need to add below for the rootNumber to be "C7000000"
Description:
<VarDef id="_rootNumber" algorithm="ext.thales.palma.external.kiwi.impl.ODataNumberAlgorithm">
<Attr id="rootNumber" />
</VarDef>
I think you'll need to use CaseBranch. This article shows some examples for using it: https://www.ptc.com/en/support/article/CS219911
