Has anyone added code in their OIR to use a specific sequence based on an attribute associated with the soft-type? Instead of have x amount of OIRs to go with X amount of sequences,
we wanted to use 1 OIR, and within that OIR, look at an attribute(say Facility with a value of 'A1TestStand') and using the attribute's value to build the required sequence, SSC_A1TestStand_SEQ.
I looked at the CaseBranch example in the Help Center, but it is a little confusing. Thanks in advance!
Send lawyers, guns, and money...the sh!t has hit the fan!
