Only a Windchill site administrator can edit a workflow template
lury
Windchill PDMLink 11.0 M030-CPS11
Only a Windchill site administrator can edit a workflow template.
Users who are members of the Administrators group at the site level cannot modify an existing workflow template.
Description
Editing a workflow template.
When checking the syntax of an existing block, the check is successful.
When creating any new block (for example, Conditional Router), when checking the syntax, an error message is displayed:
ERROR : WF_EXEC_EXPR <adminPLM> -    compile - OUT: D:\ptc\Windchill_11.0\Win
dchill\temp\WfExpression_<adminPLM>.java:17: error: '{' expected
public class WfExpression_<adminPLM>{
1 error
where <adminPLM> is the login of a user who is a member of the Administrators group at the site level
File with name ”D:\ptc\Windchill_11.0\Windchill\temp\WfExpression_<adminPLM>.java”
not in the specified directory.
If you add a new block under the password of the administrator of the Windchill site under which Windchill was installed, the syntax check is successful.
What can I do so that all users in the administrators group can change the workflow template?
I tried to add a user at the site level to the group:Workflowadministrators and WorkflowAuthors.
Did not help.
7 REPLIES 7
DmitryC
(To:lury)
Hi Lury,
To be simple, editing workflow templates require 2 different levels of access:
  • Anything related to Java coding
  • Everything else (teams, deadlines, basic blocks, notifications, etc.)
All Java-related modifications (as, potentially, extremely harmful), including checking syntax, require Site admin.
I would strongly recommend editing workflow templates in a test environment first for multiple reasons. You may also have slightly more relaxed rules about who can be a site admin on your test server.
Then a production site admin would just export/import the new _tested_ version of a workflow each time.
There MAY be a way to allow specific groups (not site admins) to edit java expressions, but I am not aware of it, you may ask the support about it. And, in my opinion, you definitely should have a good reason for doing this.
Kind regards,
Dmitry
yadavankur
(To:lury)
I checked just now, orgadmin could not create expression robot. Added him to Workflow Author group and expression robot button was available, everything you describe not working worked for me. Maybe your user is missing some other permission?
lury
(To:yadavankur)
I work as a user in the Site Administrators group.
Windchill allows me to create a new workflow template or to modify an existing one, modify and save it.
Windchill allows me to edit the contents of an existing process.
Allows editing Java code in existing blocks. The syntax check succeeds.
A syntax check error appears only when creating a new block!
The error is displayed even if the new block is empty and does not contain any Java code!
I added myself to the Workflowadministrators and WorkflowAuthors group.
Nothing changed.
What rights should I add?
This seems like a bug in Windchill
The error appeared after updating Windchill PDMLink 10.1 M040 to Windchill PDMLink 11.0 M030-CPS11
The update was successful.
On Windchill PDMLink 10.1 M040, everything worked correctly.
As DmitryC wrote, we are editing the process on a test server. Then we transfer the changes to the working server as a user, the administrator of the Windchill site.
But I wanted to fix the error so that other users in the Site Administrators group could edit the workflow template.
Maybe I need to enter additional settings in the system?
For example, Windchill has added advanced settings so that the user can access the help system.
By default only Windchill Administrators can access Windchill Help.
Here is a link to the help solution https://www.ptc.com/en/support/article?n=CS161210
It says here how to connect users to the help system or disable the check altogether.
DmitryC
(To:lury)
Can you try saving the workflow before you check syntax?
I can get similar behavior when the workflow does not physically exist yet. For example:
1. Create workflow
2. Create Execute Expression robot
3. Paste my code
4. Hit 'Check Syntax' button <- Error here
But if I save the workflow first - everything just works:
1. Create workflow
3. Paste my code
4. Save the workflow
5. Hit 'Check Syntax' button <- everything works
Dmitry.
lury
(To:DmitryC)
Thanks DmitryC
After saving the template, the verification is successful.
It is not clear why the site administrator does not need to save the process?
The syntax check passes for the Site Administrator without first saving.
lury
(To:DmitryC)
Found a solution to this problem
The username must not contain special characters (for example, "@", "-", ".")
If the username does not contain special characters, verification is successful without saving the process!
See link
https://www.ptc.com/en/support/article?n=CS272001
https://www.ptc.com/en/support/article?n=CS296242
G_Gerard
2-Explorer
(To:DmitryC)
1. Create workflow
3. Paste my code
1. Create workflow
3. Paste my code
Dmitry.
Very valuable information, it is not at all blogs that we find this, congratulations I was looking for something like that and found it here.
