Opening data.wcdti or downloading a file from IE is downloaded DTIActionServlet.servlet instead the required file
acurcio
when i'm downloading a file from Windchill with desktop integration activated (using Internet Explorer) download a file named DTIActionServlet.servlet instead my file.
If i disable desktop integration in my setting is working but i need it.
Using Firefox it's the same. FF download a file data.wcdti, opening that is download same file DTIActionServlet.servlet.
This happen with any files.
Do you have any suggestion?
Best reguards
We have faced this issue and it was fixed with the registry settings mentioned in  CS105737
Check following registry entries in HKEY_CLASSES_ROOT\MIME\Database\Content Type\text/plain
  • ​Name: CLSID,  Type: REG_SZ,  Data: {25336920-03F9-11cf-8FD0-00AA00686F13}
  • Name: Encoding, Type: REG_BINARY, Data: 07 00 00 00
  • Name: Extension, Type: REG_SZ, Data: .txt
Thank you
Binesh Kumar
Barry Wehmiller
10 REPLIES 10
There are same problem when i try to login in explorer to Windchill. After I typed the credentials begins the downloading of the file servlet
syadala
(To:acurcio)
Hi Alessandro Curio,
              Please check your Desktop Integration settings. We have observed this Issued with DTI.
Sudhakar
Sorry which setting i have to check?
syadala
(To:acurcio)
Open Quirc Links > My Settings > Preferences and verify the highlighted setting.Snap0170.jpg
I can't disable it. I need desktop integration
Thank you
Binesh Kumar
Barry Wehmiller
Probably it's the correct answer! I'm testing in some machine, thank you!
We have the same problem.  I checked my registry settings, they seem to be according CS105737
I am sure you would have tried a clean re-installation as well?
Very good! I'm resolved with your help Kumar!
Very thanks!
