Opening data.wcdti or downloading a file from IE is downloaded DTIActionServlet.servlet instead the required file
acurcio
when i'm downloading a file from Windchill with desktop integration activated (using Internet Explorer) download a file named DTIActionServlet.servlet instead my file.
If i disable desktop integration in my setting is working but i need it.
Using Firefox it's the same. FF download a file data.wcdti, opening that is download same file DTIActionServlet.servlet.
This happen with any files.
Do you have any suggestion?
Best reguards
BineshKumar1
(To:acurcio)
We have faced this issue and it was fixed with the registry settings mentioned in  CS105737
Check following registry entries in HKEY_CLASSES_ROOT\MIME\Database\Content Type\text/plain
  • ​Name: CLSID,  Type: REG_SZ,  Data: {25336920-03F9-11cf-8FD0-00AA00686F13}
  • Name: Encoding, Type: REG_BINARY, Data: 07 00 00 00
  • Name: Extension, Type: REG_SZ, Data: .txt
Thank you
Binesh Kumar
Barry Wehmiller
10 REPLIES 10
acurcio
(To:acurcio)
There are same problem when i try to login in explorer to Windchill. After I typed the credentials begins the downloading of the file servlet
syadala
(To:acurcio)
Hi Alessandro Curio,
              Please check your Desktop Integration settings. We have observed this Issued with DTI.
Regards
Sudhakar
acurcio
(To:syadala)
Sorry which setting i have to check?
syadala
(To:acurcio)
Open Quirc Links > My Settings > Preferences and verify the highlighted setting.Snap0170.jpg
acurcio
(To:syadala)
I can't disable it. I need desktop integration
BineshKumar1
(To:acurcio)
Thank you
Binesh Kumar
Barry Wehmiller
Probably it's the correct answer! I'm testing in some machine, thank you!
We have the same problem.  I checked my registry settings, they seem to be according CS105737
I am sure you would have tried a clean re-installation as well?
Very good! I'm resolved with your help Kumar!
Very thanks!
