Hello Experts, i was interested in exploring the OSLC api on Windchill,
I could not find any documentation on how to enable this on Windchill.
Most of the documentation is for RV&S and not Windchill .
Is there a OSLC api on Windchill?
I know there is Odata based Rest API.
Can someone pls point me to the documentation related to Windchill OSLC api.
Article - CS311821 - Windchill OSLC Server support added to Windchill PDMLink 11.1 M020 CPS08 and 11.2.0.2 (ptc.com) will provides details on required Windchill configurations to support Windchill OSLC services.
I'm not responsible for Windchill PLM, but I did find some information in the Help - not much on the customization points or API though.
I'll raise this with a PLM colleague who may have more information to share, you could also contact PTC Support.
regards,
Patrick
Thanks for the reply, The architecture diagram in there shows that the OSLC connector is used through Thingworx, does this mean if i want to use WIndchill Oslc i need to have Thingworx?
Patrick,
Thank you for your support!
Hello @SM_9917423
Just my thoughts because I do not use OSLS.
If you use OSLS then do you need to write a OSLS API to get data from Windchill ?
Windchill has own restapi that can be used in OSLS I guess.
ThingWorx use a Windchill REST Api to drill a data and then integrate it with other systems.
So documentation for the rest api is in Windchill instalation
general documentation
https://serverAdress/Windchill/app/#ptc1/apiDocs/apiDocs?oid=OR%3Awt.org.WTUser%3A207&u8=1
REST servicess documentation
https://wchserverAdress/Windchill/netmarkets/html/wrs/doc.html
REST Servicies user guide (PDF)
hope this can help
PetrH
Thanks for the reply @HelesicPetr
This looks interesting, thanks
It turns out i can hit the catalog on my dev instance, need to explore this further
Here is the Windchill help center topic on OSLC server: Open Services for Lifecycle Collaboration (OSLC) Server (ptc.com)
