Oslc API on windchill
SM_9917423
Hello Experts, i was interested in exploring the OSLC api on Windchill,
I could not find any documentation on how to enable this on Windchill.
Most of the documentation is for RV&S and not Windchill .
Is there a OSLC api on Windchill?
I know there is Odata based Rest API.
Can someone pls point me to the documentation related to Windchill OSLC api.
Article - CS311821 - Windchill OSLC Server support added to Windchill PDMLink 11.1 M020 CPS08 and 11.2.0.2 (ptc.com) will provides details on required Windchill configurations to support Windchill OSLC services.
9 REPLIES 9
@PatrickOllerton Please take a look.
I'm not responsible for Windchill PLM, but I did find some information in the Help - not much on the customization points or API though.
I'll raise this with a PLM colleague who may have more information to share, you could also contact PTC Support.
regards,
Patrick
SM_9917423
(To:PatrickOllerton)
Thanks for the reply, The architecture diagram in there shows that the OSLC connector is used through Thingworx, does this mean if i want to use WIndchill Oslc i need to have Thingworx?
 Patrick,
Thank you for your support!
HelesicPetr
(To:SM_9917423)
Hello @SM_9917423
Just my thoughts because I do not use OSLS.
If you use OSLS then do you need to write a OSLS API to get data from Windchill ?
Windchill has own restapi that can be used in OSLS I guess.
ThingWorx use a Windchill REST Api to drill a data and then integrate it with other systems.
So documentation for the rest api is in Windchill instalation
general documentation
https://serverAdress/Windchill/app/#ptc1/apiDocs/apiDocs?oid=OR%3Awt.org.WTUser%3A207&u8=1
REST servicess documentation
https://wchserverAdress/Windchill/netmarkets/html/wrs/doc.html
REST Servicies user guide (PDF)
https://www.ptc.com/en/support/refdoc/Windchill_REST_Services/2.5/wrs?&art_lang=en&posno=2&q=windchill%20rest&DocumentType=Reference%20Document&source=search&_gl=1*pw3616*_ga*MjA1NjM1MzcyNS4xNjc4OTUwMDM0*_ga_1QBT6P6HR1*MTY4MjQwMDk2Mi45OS4xLjE2ODI0MDcxMjguMC4wLjA.*_ga_CBN5QVB9VJ*MTY4MjQwNzA5MC4yOS4xL....
hope this can help
PetrH
SM_9917423
(To:HelesicPetr)
Thanks for the reply @HelesicPetr
If needed may be we might have to write some custom Oslc Api, but i am hoping i wont need that.
I am familiar with Windchill Rest API and we are using that as part of my development.
Oslc was suggested by PTC as part of a use case we have, hence the need to explore Oslc Api
SM_9917423
(To:TanuJolly)
This looks interesting, thanks
It turns out i can hit the catalog on my dev instance, need to explore this further
Here is the Windchill help center topic on OSLC server: Open Services for Lifecycle Collaboration (OSLC) Server (ptc.com)
