Our DB Server IP needs to be changes Is it possible? where all I need to make changes for it.
SJ_9578736
3-Newcomer
I am using Windchill 11.0 and DB server IP needs to be chn
I noticed db.properties doesnt even have IP address as properties , so it is safe to change the ip.
Also please take a look at https://www.ptc.com/en/support/article/CS358799
Yes it is possible. Only db.properties needs to be changed.
Ajit
That is correct. You just need to update hosts file and/or DNS if db.properties is using hostname.
