In the organisation context we have 568 products, for which Product level OIRs have been such that Numbers are auto generated for WTPart (it has final = "false" for Numbering). But now the requirement is such that for all products the numbering should be manual. I created an OIR at Org level with final = "true" value and set auto numbering off, but still numbering is auto generated only. Is there some way to override the product level OIR at Org/Site level so that we can have manual numbering, as going manually and changing OIRs for all products is a tedious job.
We solved this issue using Database. For OIRs there is table TYPEBASEDRULE which has a column ENABLEDFLAG. If its value is 0 it means enabled and if its 1 it is disabled. So we wrote the following command to disable the OIR in all our products :
Part_Havells is name of our OIR
