After uploading drawing into Windchill, the PDF will be generated,however, the Chinese fonts are showing as all "SQUARES" in PDF.
Following https://www.ptc.com/en/support/article/CS35859?art_lang=en , still same issue.
really need help to solve the issue.
No solution?
I'd suggest opening a Support case, for this issue, to get to the bottom of this.
It certainly does seem like some language pack/locale/language issue, with the configuration in either the product, or the browser being used, since it's not showing the multibyte characters properly.
Mike
