Hello experts,
We need to extract all creo assemblies, parts and drawings form PDM link 10.0 in bulk.
we have identified some capabilities. It would be great if you can suggest a list of best methods to do bulk extraction from PDM intralink 10.0.
I have a bulk download utility that I wrote for doing what you are asking.
In short, the utility is run in a Windchill shell.
The admin (or whoever) inputs the EPMDoc type, folder path to download to, username, password
Then stand back and let it run. Download is quick per file but if downloading 50GB worth of files it will take a while.
The number of files it can do is probably more limited by diskspace than anything else.
I decided to including entering doc type argument in order to run in three shells at once in the event there is a massive amount of data to download. One downloads assemblies, one downloads drawings (and formats), one downloads components.
It also creates a log of cadname rename history in the event the cad file was renamed.
So, that would be my recommendation.
Hello d_graham,
Thanks for the response. I am unable to build my java application with out wt.jar file.
Could you please guide initial steps to get access and choose required .jar files for writing an external java application that can connect to windchill.
Regards
Dhamodharan
