Hi All!
We put MC gatekeeper to WC so when user checks-in proe objects that have MC errors and/or MC have not
run on them, check-in will stop with errors. The problem is when you are working with legacy data it is all out
of date according MC configuration - MODEL_CHECK parameter records the date MC has run and WC checks
if it is not more than 180 days. I want to disable that. So if model has not been changed it does not matter if it
has been more than 180 days.
Do you know how to do it?
Dmitry
