PDMLink Error (no Cache designated vault or active folder for Cache)
MikeLockwood
22-Sapphire I
There have been some bugs in some releases where certain Pro/E actions cause the current folder to convert to Read-Only.
Site, Utilities, External Storage Admin, Vault Config - check if the latest folder is enabled and not Read Only.
Hellow All,
There are couple of reasons which leads to the below mentioned situation.
Some of them are:-
1) The HDD to which the folder is mounted is full.
2) Some access issue.
3) Checking in of wrong data.
and many more.
Basically when the "Defaultcache vault or folder" is set as "Read only" ,
all the uploads to the windchill fails . The reason is that Windchill is
unable to write anything.
Solution: - Go to Vault configuration window and uncheck the “Read Only for”
either "Defaultcache vault or folder" and it is done.
Hope this helps.
Let me know if you need any more information around it.
Mayur
On Fri, Apr 16, 2010 at 4:22 AM, Steve Burke <
-> wrote:
> PDMLink Error on check in or upload
> Any input on this would be a big help PDMLink M040, WF3 M230, IE 6+
> (There is no Cache designated vault or active folder for Cache designated vault on Local Master Site.)
> Thanks
> Steve
