PDMLink customization
rboneti
7-Bedrock
Hi everybody!
I need to customize some functionalities of Windchill with my own code. What programming language can I use? Where could I found reference documents?
Hi Robson,
Here are the Customizer Guides for Windchill:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS60345
Most of Windchill is Java and JSPs, but it depends what your are looking to customize. The Customizers Guide is a good place to start.
You can find further information (info*engine/ adapter guides) from our support portal:
https://support.ptc.com/appserver/cs/portal/
Good luck with your implementations!!
Jarrett
Hi Robson,
Jarrett
Thank you Jarrett!
It's helping a lot!
