I have a situation that is unstable and erratic. We are running Windchill 9.1 M060. Prior to go live we tested out the back up scenario to do cold backups by shutting down both the application and database servers. after 2 months we started to get info engine errors and search functionality not working. All services are started and you can log in and access windchill products, but are unable to use the search engine. PTC recommended taking everything down and clearing out caches and deleting the Tomcat Work folder. That works but now it is getting to the point the system will go a few days without problem then search will be down 2 or 3 days after the backup script restarts the application services. Who else is having this problem if any and is there a miracle solution to get the services to restart after backup and search and the info engine to run properly again? Any and all help will be appreciated and shared. Thanks
We've seen the exact behavior ever since upgrading to 9.1 M060 a few months ago. Windchill will restart fine for a few days, then the next day searches wont work. Usually shutting down all services and restarting fixes the problem. I'm going to experiment with the startup order as suggested and see what happens.
In Reply to Ray Connole:
We are seeing the same issue as this one described in below link (some random jsp files not found but bouncing Windchill and Tomcat solves the issue then some other jsp files not found then keep bouncing WC and Tomcat..... We are in 9.1 M060) :
https://www.ptc.com/appserver/cs/view/spr.jsp?n=2025952
The above SPR is closed by no resolution posted. Contacted PTC support but hasn't got response yet.
Do you think upgrading Java build may solve it?
