HI friends, Anyone worked on PLM Webservices? Recently PTC had released WebServices Framework For M050. It would be great if everyone share their ideas/experiences on the web services in PLM.
This framework document has an example but that does not have a DataBase hit.
It would be interesting to know if DB hit can be done by using Java Based Web Services in Windchill.
Hello
I dont knowif the M050 framework can directly query (maybe modify) the database & this is not my area of expertise (who knows what is), but I have seen where some one used apache axis2 web services to run oracle stored procedures & maybe even run jdbc for query/modify the oracle db &/or both.
But I would really like to see how the M050 framework does in the db area &/or can be coaxed into doing so.
L Jett
Hi friends,Want ur inputs for the below scenario :
Created a webservices and was able to retrieve data from DB successfully. But this works only when I ran the services as jar in Shell (command to run services in shell is specified in Webservices Frameworkdocument). When I try to invoke Windchill webServices by using the wsdl file generated, there is an exception in Tomcat:
javax.xml.ws.WebServiceException: java.lang.RuntimeException: Unauthenticated requests are not allowed. at com.sun.xml.wss.jaxws.impl.SecurityServerTube.processException(SecurityServerTube.java:381) at com.sun.xml.ws.api.pipe.Fiber.__doRun(Fiber.java:593) at com.sun.xml.ws.api.pipe.Fiber._doRun(Fiber.java:557) at com.sun.xml.ws.api.pipe.Fiber.doRun(Fiber.java:542) at com.sun.xml.ws.api.pipe.Fiber.runSync(Fiber.java:439) at com.sun.xml.ws.server.WSEndpointImpl$2.process(WSEndpointImpl.java:243) at com.sun.xml.ws.transport.http.HttpAdapter$HttpToolkit.handle(HttpAdapter.java:471) at com.sun.xml.ws.transport.http.HttpAdapter.handle(HttpAdapter.java:244) at com.sun.xml.ws.transport.http.servlet.ServletAdapter.handle(ServletAdapter.java:135) at com.sun.xml.ws.transport.http.servlet.WSServletDelegate.doGet(WSServletDelegate.java:129) at com.sun.xml.ws.transport.http.servlet.WSServletDelegate.doPost(WSServletDelegate.java:160) at com.sun.xml.ws.transport.http.servlet.WSServlet.doPost(WSServlet.java:75) at javax.servlet.http.HttpServlet.service(HttpServlet.java:637) at javax.servlet.http.HttpServlet.service(HttpServlet.java:717) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at wt.httpgw.filter.WTContextBeanFilter.doFilter(WTContextBeanFilter.java:48) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at wt.httpgw.filter.TrustedAuthFilter.doFilter(TrustedAuthFilter.java:123) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at wt.servlet.CompressionFilter.doFilter(CompressionFilter.java:224) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at wt.servlet.RequestInterrupter.doFilter(RequestInterrupter.java:324) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at wt.servlet.ServletRequestMonitor.doFilter(ServletRequestMonitor.java:1417) at wt.servlet.ServletRequestMonitorFilter.doFilter(ServletRequestMonitorFilter.java:54) at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233) at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191) at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127) at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102) at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109) at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298) at org.apache.jk.server.JkCoyoteHandler.invoke(JkCoyoteHandler.java:190) at org.apache.jk.common.HandlerRequest.invoke(HandlerRequest.java:291) at org.apache.jk.common.ChannelSocket.invoke(ChannelSocket.java:769) at org.apache.jk.common.ChannelSocket.processConnection(ChannelSocket.java:698) at org.apache.jk.common.ChannelSocket$SocketConnection.runIt(ChannelSocket.java:891) at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:690) at java.lang.Thread.run(Thread.java:619) Caused by: java.lang.RuntimeException: Unauthenticated requests are not allowed. at com.ptc.jws.security.SecurityContext.handleMessage(SecurityContext.java:54) at com.ptc.jws.security.SecurityContext.handleMessage(SecurityContext.java:33) at com.sun.xml.ws.handler.HandlerProcessor.callHandleMessage(HandlerProcessor.java:292) at com.sun.xml.ws.handler.HandlerProcessor.callHandlersRequest(HandlerProcessor.java:135) at com.sun.xml.ws.handler.ServerLogicalHandlerTube.callHandlersOnRequest(ServerLogicalHandlerTube.java:142) at com.sun.xml.ws.handler.HandlerTube.processRequest(HandlerTube.java:116) at com.sun.xml.ws.api.pipe.Fiber.__doRun(Fiber.java:598) ... 43 more
Hi Friends,
When a webservice call is made from another system/application, what are the different authentication scenarios available in PLM web services ? Please do share the options and learnings !!
