PSI Folder deleted
EC_10581209
PSI Folder deleted
my PSI Folder got deleted, now i want to install Windchill ProjectLink how can I do that knowing that my PSI folder is deleted
Regards
I would contact PTC Tech Support for this case. I did not find a documented procedure in the knowledge base. In either case, you need to beef up your backup and recovering procedures since this folder should not have been deleted and unrecoverable.  Before attempting to install ProjectLink, I would ensure that PSI is fully recovered and you have a proper backup process in place for both Windchill install and the DB.
I agree with @avillanueva - You may end up having to install an exact copy of Windchill features on another server and use those PSI folders/files (with some massaging) PTC should be able to help you.
You can install Windchill the same way you did originally (if you know what that is) in a different location with a different dB. Then copy that installations PSI and edit the property files under the copied PSI to match your original installation.
