PSI for Oracle configuration is hung
Steven_007
I am building a test system for Windchill 11.0.
Install Oracle 12c. Run the 11.0 PSI Setup to configure Oracle.
It has been running for almost 12 hours and is stuck at 21% complete.
No user problem,no permission problem,
I try to kill the process and start over with a clean Oracle install and then rerun the PSI Setup.
But the completion rate is still only 21%.
Find the reason:
Operating system memory is 256G.
Reduce the memory to 64G. Installation succeeded.
I try to install windchill 12.0 in this environment.
Install Oracle 19c. Run the 12.0 PSI Setup to configure Oracle.
Installation succeeded, no problem.
BenLoosli
(To:Steven_007)
What is your OS?
Which version of Oracle 12c, R1 or R2?
Which CPS of 11.0 are you installing?
I have had the OCU stall a few times. Kill it and start the PSI over.
OS: Windows Server 2016 Datacenter
Oracle Version: Oracle 12.1.0.2
Windchill Version: Windchill 11.0 M030 CPS11
I tried to install it several times,but have the same result.
Find the reason:
