PTC Common Name
mszwabowski
PTC Common Name
I'm using a restricted parameters list that creates a pull-down menu for a DESCRIPTION parameter in a start part in Windchill PDMLink 10.2.  The user selects the appropriate item from the list and the DESCRIPTION parameter gets populated.  I successfully created a relation that also populates the PTC Common Name.
If the user saves the file, the PTC Common Name gets populated.  If the user selects a different item from the pull-down menu and saves the file, the PTC Common Name changes accordingly.  However, if the user tries to select a different option from the pull-down menu after the file has been Saved & Uploaded, the following message appears:
Some relations are no longer satisfied in *filename* for PTC_COMMON_NAME
Is there a way to set the PTC_COMMON_NAME back to being blank after a file has been Saved & Uploaded in Windchill?
1 ACCEPTED SOLUTION
TomU
(To:mszwabowski)
Nope.  PTC Common Name is a non-versioned Windchill attribute ("Name").  That means that every single version of that model will share the same common name.  Think of this like "file name" or "number".  These three attributes are shared across all versions of the same model and, once set, cannot be changed from Creo.
TomU
(To:mszwabowski)
mszwabowski
(To:TomU)
Thank you for letting me know.  I figured as much after I couldn't get it to work but thought it wouldn't hurt to ask.  I'll just have to find another way to standardize the common name.
