PTC FlexNet Licensing?
ptc-4271844
This is the case:
-Server application software installed (according to Relex 2011 Team Installation Guide)
-License obtained (according to How to obtain and install a new FlexLM License Pack for Relex 2011)
-Client SW installed (according to Relex 2011 Team Installation Guide)
-The server has another program using FlexNet licensing
Error message when trying to run Relex 2011:
License initialization failed: Flex initialization error. (-97)
Error Code (-97) says:
The desired vendor daemon is down.
1) Check the lmadmin or lmgrd log file, or 2) Try lmreread.
lmgrd log file says:
14:10:54 (lmgrd) Done rereading
14:10:54 (lmgrd) FLEXnet Licensing (v10.8.6.2 build 59284 i86_n3) started on dr-projh (IBM PC) (10/20/2011)
14:10:54 (lmgrd) Copyright (c) 1988-2008 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
14:10:54 (lmgrd) US Patents 5,390,297 and 5,671,412.
14:10:54 (lmgrd) World Wide Web: http://www.macrovision.com
14:10:54 (lmgrd) License file(s): C:\Program Files\flexnet\licensing\license.dat
14:10:54 (lmgrd) lmgrd tcp-port 7788
14:10:54 (lmgrd) Starting vendor daemons ...
14:10:54 (lmgrd) Started ptc_d (pid 3976)
14:10:54 (ptc_d) FLEXnet Licensing version v10.8.6.2 build 59284 i86_n3
14:10:59 (lmgrd) ptc_d exited with status 25 (Invalid host)
14:10:59 (lmgrd) Please correct problem and restart daemons
The support tells me to install PTC Flexnet first, then others, otherwise it`s not supported. I dont`t think this is an option because other workers use the SW (which allready licensed) daily and we will not take the risk of uninstalling other SW products. The FlexNet licensing system has to be ment for more than one product!?
I read another thread (http://communities.ptc.com/message/18228), which dealed with the same problem but the answers did not help me.
Can you please help me to solve this annoying problem?
Thank you.
0 REPLIES 0
