Upgraded a testing environment to 10.2 M010 to test using process plans from the structure view of a Part, but do not see it there. Anyone using this new feature? Is there config that needs to be in place to enable this functionality? Thanks.
The link above describes the functionality but I couldn't find how to access it. The way to access it is from PDMLink to use the actions button that would typically be used to create a new part, ECR, etc. From there New process plan will open it with its own structure view with some of the functionality that exists in the process plan explorer. Not all of the functionality exists and the layout/wording is different when compared to the process plan explorer.
Haven't test it yet , but try from the structure tab of the Proces Plan himself . Not from the structure tab of the part
regards
Thanks for the response but the Process Plan explorer works, but it is a Java applet. This release is supposed to allow maintenance of the process plans in much the same manner as a BOM from within PDMLink.
This link describes it: http://www.ptc.com/appserver/wcms/relnotes/note.jsp?&im_dbkey=158551&icg_dbkey=826
yes ... no new button in the HTML UI ribbon ...
my 10.2 is not ready yet ....
