Anyone sending plans back and forth to Windchill from Project?
I exported a plan from PJL and opened it in MS Project. Populated the PTC.soft_attribute_1 value, however upon import the attribute column is still not displayed. What gives?
WC 12.0.2.13
So the answer here is that PTC's documentation / article in this was poorly written. After I was able to trace the root cause - I got PTC to update the article.
