PV Worker Common File System Permissions
davehaigh
On one network, I have:
* Windchill running as a service owned by Local System.
* On the worker machine GSWorker is running as an actual user. (Needed because we are using SSL)
* I have two worker machines, one for MS Office type files and another for ProE files.
* One is configured with an FTP server the other just uses a common file system path.
* This setup works.
On our other network, more secure, I have: essentially the same thing except currently I only have one worker machine.
* Windchill service owned by Local System,
* GSWorker service owned by a real user.
* Using a common file system path
* This setup fails, log file says:
Problem creating directory \\<server-name>\cad_viewables\w1i1j2. It already exists as a file
Problem creating directory \\<server-name>\cad_viewables\w1i1j2. Do not have write access
From the windchill server I can write, & delete files in \\<server-name>\cad_viewables\<file: \\%3cserver-name%3e\cad_viewables\="> No problems
The hot-line is trying to tell me it's because I have Windchill running as Local System. I'm not convinced. Does anyone know for sure what user is writing the files in that location?
Also can I get around this permissions issue by using an FTP server?
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
pwilliams-3
(To:davehaigh)
I would recommend using an ftp server. I was wondering why you would use
UNC for one and FTP for the other? They're very easy to setup using IIS
for the worker.
PATRICK S WILLIAMS
Information Technology
Mechanical Engr Solutions
Missile Systems
Raytheon Company
+1 520.545.6995 (office)
+1 520.446.0244 (pager)
+1 520.545.6399 (fax)
6221 S Palo Verde Rd
Tucson, AZ 85706-5093 USA
www.raytheon.com
Follow Raytheon On
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
On Thu, 2011-03-31 at 11:47 -0700, Haigh, David A. wrote:
David,
Hoping below does not sound obvious and stupid.
I do not think it is because it is a service - I think there is just a
mismatch on users.  I would check to see who windchill is running as.
You can use the task manager to check.  I would guess you are not
logging in as the same user the service is running as.  If you need more
information than - use the task manager drop me an email and I can give
you more detail.
--Bob
> ·        Windchill running as a service owned by Local System.
> ·        On the worker machine GSWorker is running as an actual user.
> ·        I have two worker machines, one for MS Office type files and
> ·        One is configured with an FTP server the other just uses a
> ·        This setup works.
> ·        Windchill service owned by Local System,
> ·        GSWorker service owned by a real user.
> ·        Using a common file system path
> ·        This setup fails, log file says:
> Problem creating directory \<server-name>\cad_viewables\w1i1j2. It
> Problem creating directory \<server-name>\cad_viewables\w1i1j2. Do
> \<server-name>\cad_viewables\  No problems
> The hot-line is trying to tell me it’s because I have Windchill
> running as Local System. I’m not convinced. Does anyone know for sure
> David Haigh
> Phone: 925-424-3931
> Fax: 925-423-7496
> Livermore, CA 94550
Bob Lehman
Email: -
Mobile: (503)888-1471
