Part Association Image No Visual
MtnDog
One assembly is an Image association to the other.  From what I understand no attributes are passed from image item to wtpart, but in a product structure the Visual, or image, should remain.  What I see is that in the product structure, after the build, the owner wtpart appears twice, so far so good, but the visual in the Structure > Visualization tab is the owner wtpart and not the image part.
As PTC and other resources have stated the purpose of Image is to show a cable in many configurations, but have one item master.  Is there something i'm doing wrong?  Can you describe the method you go about doing this.  Maybe it's my process.  Created Image Association > Build Structure.
Thanks in advance
0 REPLIES 0
