Possible to have access control on a State and Revision
lgrant
We have a question if it is possible to allow an action for a numeric revision at a given state (In Work) but not allow the same action at alpha revision at the same state (In Work)?
The action is Delete.
RandyJones
(To:lgrant)
You can probably create your own includeFilter. However there are 23 actions with name of delete (Windchill PDMLink 11.0 M020) so it might take a bit to figure out exactly which delete action you need to tweak. I would start with the one for type = object.
Keep in mind this will only hide the delete action. It will not change permissions (ie Policy Administration).
